Results 1 to 9 of 9
Thread: Effect on LiFePO4 battery stability when wired in series
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Michael
    Robots
    Shu! (Building) - BW / The Honey Badger - FW / Kaizen (In planning) - HW
    Location
    Somewhere on the Wirral
    Posts
    111
    Post Thanks / Like
    Hi Everyone!
    I've received a pair of 2SP1 30C LiFePO4 batteries for The Honey Badger. A single battery pack is 6.6v so the drive motor spins slower than that in the 12v 1.2ah SLA battery that was previously connected to the motor (the robot did have 1 battery per motor).
    Would tying up the battery packs in series (to make 13.2v) be an issue for the stability of the cells in the packs at all (assuming they are charged at the same time)? My plan was to tie the two packs together to get to 13.2v so the motor spins at a similar rotational speed to the SLA batteries and then split the circuit after the removable link before a pair of fuses.
    Team Kaizen
    Shu! - BW - Build Thread
    The Honey Badger - FW - Build Thread
    Kaizen - HW (In the planning stages)
    overkill's Avatar
    Member
    Status
    Offline
    Name
    Nick Martin
    Robots
    Mr Mangle - Australian 2015 Featherweight Champion 2016 UK Gladiator Shiny Scissorhands Decimator
    Location
    Sydney Australia
    Posts
    875
    Post Thanks / Like
    That is absolutely fine, they don't even really have to be charged exactly the same. Its when you connect Lipos in parallel that you have to be careful.
    maddox10's Avatar
    Member
    Status
    Offline
    Posts
    2,294
    Post Thanks / Like
    I guess we have a little confusion about cells in series and cells in parallel.
    Good LiPo and LiFePo4 packs have balancing leads, especialy to charge each cell.
    That is also the reason for the rule to use dedicated chargers/balancers for those packs. There are tricks
    Drawing power from the packs is another matter.
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Michael
    Robots
    Location
    Posts
    111
    Post Thanks / Like
    Thanks, I do understand that - I wasn't planning to have both batteries on charge when wired up in this manner (though having re-read my original post, it does look as if I was asking about charging them at the same time as well), just when inside the robot (i.e. whilst in use). From the sounds of it, would be OK to do.
    Team Kaizen
    overkill's Avatar
    Member
    Status
    Offline
    Name
    Nick Martin
    Robots
    Location
    Sydney Australia
    Posts
    875
    Post Thanks / Like
    This part of your post is confusing me; 'split the circuit after the removable link before a pair of fuses'
    Does that just mean you want a separate fuse before each drive motor ESC? Not many people bother with that.
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Michael
    Robots
    Location
    Posts
    111
    Post Thanks / Like
    Yes, that is what I mean though I don't see why not. Yes, it is another fuse to keep on top of but if it means one side continues to move whilst the other side is blown, I'd be happier with that than one fuse after the battery.
    Team Kaizen
    overkill's Avatar
    Member
    Status
    Offline
    Name
    Nick Martin
    Robots
    Location
    Sydney Australia
    Posts
    875
    Post Thanks / Like
    Nothing wrong with having as many fuses as you want. The fuse is only in the rules to protect the Lipo from the rest of the bot and prevent fires not to protect the electronics.
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Michael
    Robots
    Location
    Posts
    111
    Post Thanks / Like
    That is fair enough... though why does the fuse rule only appear to apply to LiPo batteries? LiFePO4 batteries appear to not be subject to this requirement under rule 7.8.
    I would have thought it was at least good practice to have at least one fitted to the wiring for a LiFePO4 powered circuit (unless it is specifically mentioned because the chemistry is safer than LiPo?)
    Team Kaizen
    maddox10's Avatar
    Member
    Status
    Offline
    Posts
    2,294
    Post Thanks / Like
    The LiFePo4's are not under the Fuse Rule because the battery Chemistry is inherently safer than LiPo.
    Worst that those can do is puff up and emit a lot of smoke.
