Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: BOB FW Series
    After my attempt on proto BOB I'm moving on to my real first FW BOB.
    The plan for this one is a 4 wheel drive with a lifter, like S.M.I.D.S.Y. So far this is the lay out for it.
    Just need to get a linear actuator and other parts to go with it. Luckily I got some spare MDF boards to use when I get what I need just to make sure the lay out works and a rough idea on the weight, btw the drill motors I'm using are about 440g.
    Knowing my luck when I start, I got the parts I need but not the tools.
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Michael
    Robots
    AW: Osu, Ikari, Ramu / BW: Shu! / FW: The Honey Badger / MW: Kaizen (Building)
    Location
    Somewhere on the Wirral
    Posts
    673
    Looks good, have you decided on what sort of speed controllers and the shell/bodywork material you are going to use in this?
    Team Kaizen
    BW: Shu! (Build Thread)
    FW: The Honey Badger (Build Thread)
    MW: Kaizen (Build Thread)
    The speed controllers I'm using are Botbitz 30a ESC and the body will be made of HDPE about 10-12mm thick.
    Maxamuslead's Avatar
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    "Blacksmith" (FW) Retired "Forge Master" (FW)
    Location
    Lincolnshire, Threekingham
    Posts
    372
    Quote Originally Posted by sean retro View Post
    us the 85a versions as you can power 2 drill motors of 1 speed controller. so you end up 1 for each side.
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Michael
    Robots
    Location
    Posts
    673
    Sounds OK although I am not sure 15a per wheel is going to be enough... I might potentially advise using a set of TZ85a speed controllers if the BotBitz controllers aren't up to the job.
    I'd also look through the build threads of Luna-Tic since this does seem similar in concept if there are any.
    Team Kaizen
    Quick question, does it matter what type of battery it is like Lipo, acid etc. to power the linear actuator?
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Michael
    Robots
    Location
    Posts
    673
    In short, no. What does matter is how much amperage is being sent to the motor. If there is too much, you'll either burn out the controller or the motor driving the actuator.
    Team Kaizen
    lowndsy's Avatar
    Astronaut
    Status
    Offline
    Name
    Steve Lownds
    Robots
    Flat Damon (FW)
    Location
    Derbyshire
    Posts
    147
    Anything with an appropriate voltage / ampage will work so the answer is mainly no it doesn't make much difference, but the chemistry will affect obvious things like the weight and dimensions as well as characteristics like power drop off and charging speed so there probably is an "ideal" battery for your requirements.
    Amperage won't be a problem, got some spare fuses what we use in plugs, felling that get a different type of fuse.
    Well I done a bit of soldering for the first time in years.
    1st try.
    2nd try.
    Working on the safety link just to see how much practise I need and from the looks of it, I'll need a bit. Also more solder.
