Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 112
Thread: BOB FW Series
  1. #21
  2. #22
  3. #23
  4. #24
    It's because the total voltage of the pack isn't what it set in the charger.
    14,8V is 4S LiPo.
    You can use the charger in a few charge modiï. Charge and balancing charge. Balancing charge is almost mandatory for us.
    If you program 4S LiPo and 2A, it will charge any battery that has a voltage between 10.8V and 16.8V.
    With balancing, the individual cells are measured, and if 1 gives a too low voltage, the charger won't start either.
  5. #25
  6. #26
    If you call up the individual cells on the display, what information is displayed?
  7. #27
  8. #28
    That is a very strange reading. 2 options.
    Or the cells are DEAD, gone, destroyed, sucked dry.
    Or there is a problem with the balancing wire harness.
    What does the main connector give as voltage?
  9. #29
  10. #30
    No, I mean, meassure the voltage of the main leads.
