Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Magnexxica
  1. #11
  2. #12
    Cool build. Looking forward to more!
  3. #13
    Triforce is 680x680x150mm with a 34kg weapon and still manages 6mm armour just fine. So I think that is doable as long as the weapon is light.
  4. #14
  5. #15
    Try it against some 4mm hardoz and see if it makes a dent.
  6. #16
  7. #17
    In terms of tooth material, it's worth looking at tool steel. We're using H13 that's been tempered to 55HRC.
    It looks like a cool build - very interesting if you can with inside the weight limit. Don't forget those removable links!
  8. #18
    Quote Originally Posted by emisnug View Post
    That's about the same as hardox 600
  9. #19
    Quote Originally Posted by TechAUmNu View Post
    A bit cheaper in my experience though. And, iirc, a yield strength of somewhere in the region of 1850MPa. But can't remember
  10. #20
