Page 19 of 20 FirstFirst ... 917181920 LastLast
Results 181 to 190 of 195
Thread: Project Squirrel
  1. #181
    Outlaw's Avatar
    Member
    Status
    Offline
    Name
    Daniel Jackson
    Robots
    Ratatoskr (FW - Under Construction)
    Location
    Sheffield, UK
    Posts
    162
    Well, managed to get more cut out, got all the panels cut, and the side panels drilled and attached, with a hole on the back to access the links too. Just need to bend the sides back into shape because the radiator the HDPE stood next to heated it up, and I never realised it until I tried to bolt it together, so more than likely, I'm going to try and bend it a little more haha. BUT progress has been made!
  2. #182
    Outlaw's Avatar
    Member
    Status
    Offline
    Name
    Daniel Jackson
    Robots
    Location
    Sheffield, UK
    Posts
    162
    Right half of the robot all bolted up, just need to do the left half, then vacuum it all out from the top, remount it all, solder the lights and motor, reattach the weapon and then a test drive. I don't think I'll be able to get a skidplate on unless someone jerry rigs me one on the day, but that's about it.
    Also, thanks to my mom, I may only be able to attend one day of the event only... unless I can convince her that someone can take me from Sheffield to Manchester... though knowing her, I highly doubt it...
  3. #183
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Michaela
    Robots
    AW: Amai, Ikari, Osu, Ramu / BW: Azriel, Shu! / FW: The Honey Badger / MW: Jibril
    Location
    Somewhere on the Wirral
    Posts
    791
    I have some offcuts of Aluminium treadplate that should suffice. I can adapt it on the day.
    BW: Azriel, Shu!
    MW: Jibril
  4. #184
    Outlaw's Avatar
    Member
    Status
    Offline
    Name
    Daniel Jackson
    Robots
    Location
    Sheffield, UK
    Posts
    162
    Well, due to my own incompetence in verbal communication, I won't be making it Saturday... BUT Sunday is a definite shout... if John allows me to join in on that day haha....
    All that needs to be done now is soldering and that's IT. And maybe a little decoration...
    EDIT: Yep, got confirmation of being able to join in on Sunday, so hopefully I'll see y'all in Manchester then.
  5. #185
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Michaela
    Robots
    Location
    Posts
    791
    Awesome-sauce, see you tomorrow.
    BW: Azriel, Shu!
    MW: Jibril
  6. #186
    Outlaw's Avatar
    Member
    Status
    Offline
    Name
    Daniel Jackson
    Robots
    Location
    Sheffield, UK
    Posts
    162
    Well, insert long explicitives here...
    despite 4 straight days of work, and a lot of pain in my body, I'm not going to be able to join in on the fun in Manchester...
    But it gives me time to recover and improve on ol' Ratatoskr a little.
  7. #187
    Maxamuslead's Avatar
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    "Blacksmith" (FW) in a bag in bits "Forge Master" (FW) battle worn "Forge Master II" (FW) in CAD
    Location
    Lincolnshire, Threekingham
    Posts
    430
    What the problems ? As we could be able to fix it at Manchester
  8. #188
    Outlaw's Avatar
    Member
    Status
    Offline
    Name
    Daniel Jackson
    Robots
    Location
    Sheffield, UK
    Posts
    162
    Everything was misaligned. The front plates and the side plates were fighting for the same space, the bolts wouldn't go in straight and it all felt like a bodge job. Just wouldn't survive in the arena.
    But I guess all is not lost, as I can just take my time for another event, and make sure everything's properly in place, easy to get on and easy to take off too, without destroying myself.
  9. #189
    Outlaw's Avatar
    Member
    Status
    Offline
    Name
    Daniel Jackson
    Robots
    Location
    Sheffield, UK
    Posts
    162
    Okay so I guess I should do an update seeming as I've not done that in a while, haha.
    So, the general consensus me and my friend is going at here, is that we're going to make Ratatoskr a little bigger. Which means redoing all of the HDPE... And although that's not the end of the world, it could be a lot better.
    And we're going to go with rounded numbers, so to speak... so lengthwise, it's going to be 60 cm long, widthwise'll be 50 cm wide, and heightwise'll be 40 cm tall. Not only will that be much better to try and organise, I can also try to get it cut out by the people of DirectPlastics... if I contact them, considering it all haha. They don't do complex shapes, but if I just ask them to do the rectangular shapes, and I cut out the necessary angles out, then it'll be all hunky dory.
    As for what's going to happen with the other pieces? Weeeeell, they're more than likely going to be reused for other projects. And the baseplate can be used as a testing bench, so to speak.
    And now I have a working area outside too! Which means Ratatoskr's been moved into that space... which is all the way down the other end of the sodding garden haha. Oh well, least I have the space to work indoors now... as long as I don't get HDPE dust in my mom's dying equipment.
  10. #190
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Michaela
    Robots
    Location
    Posts
    791
    If I may ask, why the size change? Seems to be a lot of effort down the drain.
    BW: Azriel, Shu!
    MW: Jibril
