Page 11 of 19 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 190
Thread: 300A VESC in the works, feature suggestions wanted
  1. #101
    Is that one driver per 6 FETs as in 3 high, 3 low, or 6 high, 6 low? If it's the latter your switching times may be sad..
  2. #102
    Yeah it saves a lot of board space too. With the 22r gate resistors it works out at 1.6A for a set of 3 so well within the 4amp peak on the drivers.
  3. #103
    The VEX Victor BBs have 3 FETs running off a 1A driver and have had them running at 300A, so you should be grand. I see it's only single sided FETs; if you move the gate resistors to the same side as the FETs you'd be able to get heatsinking on both sides of the board...
  4. #104
    There is going to be copper bars on that side anyway so its not a problem as the heatsink has a 2mm thick thermal pad anyway.
  5. #105
    Decided to finish off the pcb layout instead, so here is the completed board! The exposed parts will have 3mm copper on them. The cutout is for capacitors. With the whole board sandwiched between a set of aluminium plates.
  6. #106
    New pcb is now with the fab after I got the schematics checked over by some other people. Thanks to them!
    Ordered the parts that changed for the new version, mostly capacitors and more TVS diodes for ESD protection.
    Also getting the case prototype made by protolabs so that should arrive soon.
    Copper bus bars were cut at the same time as my order for Triforce and look pretty good.
    Just waiting on stuff arriving to test it out!
  7. #107
    All parts have now arrived. The boards were dispatched on Monday so should be here sometime next week.
    I got the bottom half of a case done by protolabs and the copper bus bars were cut by kcut.
  8. #108
    Been working on this slowly over the last few months to sort out the problems. I have just sent off to get the next revision of the board manufactured.
  9. #109
    That's a LOT of vias! What sort of issues have you run in to?
  10. #110
    Quote Originally Posted by overkill View Post
    Yeah, I doubt the PCB manufacturer likes me...
    When I originally designed it I was working from the VESC4 schematic, so the VESC6 software didn't really work properly. So this version follows the VESC6 schematic so that the software will work properly.
    Also added lots of ESD protection and other protection devices, changed the board shape a bit and changed all the values for bootstrap capacitors and gate resistors.
    I have a few weeks off around Christmas so I will be testing this board then.
