Page 6 of 12 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 115
Thread: Project "Blacksmith
  1. #51
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Michaela
    Robots
    AW: Amai, Ikari, Osu, Ramu / BW: Azriel, Shu! / FW: The Honey Badger / MW: Jibril
    Location
    Somewhere on the Wirral
    Posts
    791
    Looks neat - reminds me of a cross between TMHWK and Mortis. What thickness of HDPE are you planning on using?
    BW: Azriel, Shu!
    MW: Jibril
  2. #52
    Maxamuslead's Avatar
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    "Blacksmith" (FW) in a bag in bits "Forge Master" (FW) battle worn "Forge Master II" (FW) in CAD
    Location
    Lincolnshire, Threekingham
    Posts
    430
    15mm frame
    20mm axe frame
    5mm top, side and front angled (might thicken that last bit)
    compared a odd pog of currnely building which I might rename to "Bodgesmith"
  3. #53
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Michaela
    Robots
    Location
    Posts
    791
    Looks tidier than my featherweight 5mm is fairly thin mind - The Honey Badger 2.x has 10mm HDPE all around and after encountering Shrekt (a vertical spinner), there are some serious gouges in the panels so if you can thicken it up, it can only be better protection.
    BW: Azriel, Shu!
    MW: Jibril
  4. #54
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    Location
    Posts
    430
    the 5mm HDPE is the top and the angled side, the front plow should be 4/5mm HARDOX
  5. #55
    R9000's Avatar
    Roboteer
    Status
    Offline
    Name
    Rory Charlesworth
    Robots
    [AW] Anty-Clockwise 2 [AW] Brushless Pizza: Reheated [AW] aaaaaaaAAAAAAAA [BW] TN3PP [FW] Aegis
    Location
    Sheffield
    Posts
    544
    Nice bronze bushings.
  6. #56
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    Location
    Posts
    430
    aren't they smexy =P
  7. #57
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    Location
    Posts
    430
    Quick update, work colleague got a 3d printer "for his kid" and offered to print us a new battery box.
    IMG-20180116-WA0000.jpgIMG_20180116_220346.jpgIMG_20180116_190909.jpgIMG_20180116_190819.jpg
    It is only 4mm PLA, so it isn't the strongest thing in the world, but I have heard that it possible to "heat treat" it to improve the layer bonding which improve the strength (by a lot apparently).
    Also in the progress of ordering the Hardox armour and hammer from K-cut.
    I might get this bot done before the end of this century. =P
  8. #58
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    Location
    Posts
    430
  9. #59
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Michaela
    Robots
    Location
    Posts
    791
    That wedge plate looks awesome. Is it welded together at the sides?
    BW: Azriel, Shu!
    MW: Jibril
  10. #60
    TechAUmNu's Avatar
    Roboteer
    Status
    Offline
    Name
    Euan Mutch
    Robots
    Robots: Triforce(HW) ESCS: A200S & A450S (in progress)
    Location
    Edinburgh, UK
    Posts
    306
    Looks folded to me. Has the tell tale cutouts on the ends of the bend lines.
