Results 1 to 7 of 7
Thread: Argos 12v Simple Value Drill Motor Mounts
    Shakey's Avatar
    Roboteer
    Status
    Offline
    Name
    Alex
    Robots
    Far, far too many (100+).
    Location
    Fleet, UK
    Posts
    411
    Post Thanks / Like
    Argos 12v simple value drill motor mounts
    I have designed a set of mounts for the 12v argos simple value drillmotors available here: http://www.argos.co.uk/product/6161400
    More detail on the motors is available here: http://www.fightingrobots.co.uk/thre...ide-and-review
    While the drillmotors are an excellent form of drive the updated design no longer secures the motor and gearbox together independently of the drill casing. Essentially they rely on a rotating lock to keep them connected. These milled mounts lock the motor and the gearbox in place preventing them from separating.
    They are milled from 15mm HDPE and incorporate M5 threads and a locking pattern for the drill motors.
    Weight of mounts: ~60g (per pair)
    Weight with motor: ~500g
    Thread: M5
    Thread Depth: 19mm (Approx)
    Bolt spacing: 30mmx52.5mm
    Please note I am only providing mounts, you must purchase the motors directly from argos.
    Purchasing: Please head over to my webstore here, https://nutsandbots.co.uk/
    Thanks,
    Shakey
    Deathly Hallows's Avatar
    Roboteer
    Status
    Offline
    Name
    Simon Hallows
    Robots
    Proof of concept - done Beetle "Evil K'Weevil" in detailed design phase Feather concepts next
    Location
    Scotland
    Posts
    73
    Post Thanks / Like
    Blog Entries
    11
    Hello Shakey,
    Do you know if these fit the Argos 14.4V too? Don't have any measuring calipers to get accurate measurements. But I can give it a go with a clamp and a ruler, if you don't already know the answer.
    Part numbering is as follows:
    HRS-550S-14.4V
    P6928DC
    Visually they look identical
    Simon
    Shakey's Avatar
    Roboteer
    Status
    Offline
    Name
    Alex
    Robots
    Location
    Fleet, UK
    Posts
    411
    Post Thanks / Like
    I've had a glance at the 14.4v ones but have never bought one to take a look inside. My gut feeling is that they're probably fine, but I'd want to take a look at some pictures of the motor + gearbox first with some measurements before I confirm that.
    Roboteer
    Status
    Offline
    Name
    Simon Hallows
    Robots
    Location
    Scotland
    Posts
    73
    Post Thanks / Like
    Blog Entries
    11
    Please find attached some pictures of the 14.4V Argos Drill motor - so you check if compatible
    IMG_20171108_184710.jpgIMG_20171108_184802.jpgIMG_20171108_184913.jpgIMG_20171108_184821.jpg
    Hope this helps!
    Member
    Status
    Offline
    Name
    Nat
    Robots
    Short Circuit (HW RWs6) DELLapidated bANTtery (AW) LowMoe (AW) Several unnamed ants
    Location
    Eastleigh, Hampshire
    Posts
    151
    Post Thanks / Like
    That moulding looks to be the same then with an additional hammer gearbox fitted. does it look like that beige and black lump can come off the gearbox with the knobbly bits? See image attached. Does it look like it could split here? Has it been moulded into a single piece?
    Shakey's Avatar
    Roboteer
    Status
    Offline
    Name
    Alex
    Robots
    Location
    Fleet, UK
    Posts
    411
    Post Thanks / Like
    If as Roboteernat says that bit above the line comes off it should be alright, looks like the same gearbox below that.
    swanaldo's Avatar
    Roboteer
    Status
    Offline
    Name
    The Swan
    Robots
    PTE R2D2
    Location
    East Kirkby
    Posts
    3,340
    Post Thanks / Like
    they look good
