Results 1 to 9 of 9
Thread: Speeding up motor
    Roboteer
    Status
    Offline
    Name
    Tony
    Posts
    39
    Post Thanks / Like
    So I have a mondeo seat motor that I'd like to use for my lifter, was cheap but it's very slow.
    Has anyone used one for their lifter and got it moving fast enough to snap up reasonably quickly? I
    I believe I can speed it up by increasing the voltage to it (bigger battery) but if i do this how high can it take? Would I need a larger esc than the 30a ones I have too?
    maddox10's Avatar
    Member
    Status
    Online
    Posts
    2,256
    Post Thanks / Like
    Rule of tumb; maximum 150% nominal voltage rating of a motor.
    But take care. There are motors that can't handle even that much overvolting.
    And most affordable motor/gearbox combinations will expierence a seriously shortened lifespan.
    On ampères. The fuse rating on the drivers seat motor is 30 amp.
    You probably can get away with the 30A ESC, but I wouldn't venture it.
    leorcc's Avatar
    Roboteer
    Status
    Offline
    Location
    Hoogvliet, The Netherlands
    Posts
    3,316
    Post Thanks / Like
    Rule of thumb is 150% of its rated Voltage. (12V * 1.5 = 18V, 24V * 1.5 = 36V, etc..)
    Best regards,
    Leo van Miert
    http://www.team-rcc.org
    Roboteer
    Status
    Offline
    Name
    Tony
    Posts
    39
    Post Thanks / Like
    Thanks to your both.
    Is there a way to increase the speed at the tip of the lifter without increasing the voltage? Changing the length of the arms or position of the motor etc?
    R9000's Avatar
    Roboteer
    Status
    Offline
    Name
    Rory Charlesworth
    Robots
    [AW] Anty-Clockwise [FW] Aegis
    Location
    Sheffield
    Posts
    495
    Post Thanks / Like
    Lengthening the arms will increase the tip speed, as would gearing the output shaft up. However you've got to remember, in either of these cases, you're trading torque for speed, and gearing systems introduce extra energy loss through friction. If you up the voltage, you're upping your speed and torque a little, but at the expense of a bigger battery and more energy cost. These are the trade-offs you have to think about.
    Roboteer
    Status
    Offline
    Name
    David
    Location
    Blackpool
    Posts
    1,615
    Post Thanks / Like
    To speed up linac weaponry you'd need a more powerful actuator so that the attachment point can be closer to the pivot, giving you a faster response time but still generating the same tip force.
    Roboteer
    Status
    Offline
    Name
    Tony
    Posts
    39
    Post Thanks / Like
    Not sure what you mean daveimi, isn't the seat motor likely to be quite powerful given its previous life it moved people? I know slowly and not often but it'll be strong enough to use for a lifter won't it?
    Also not sure what you mean by closer to the pivot increasing the response time.
    Roboteer
    Status
    Offline
    Name
    David
    Location
    Blackpool
    Posts
    1,615
    Post Thanks / Like
    What you have is basically a linear actuator. They are slow by nature, so rather than damage it with an over volt you would be better getting a more powerful linear actuator and moving the attachment point of the actuator to the arm closer to the hinge. So for the same movement of the actuator, the arm moves a lot more quickly. This will give a much quicker movement, but require a lot more power from the actuator.
    Roboteer
    Status
    Offline
    Name
    Alan
    Robots
    Pressure Point [FW] - Finished-ish
    Location
    North Notts
    Posts
    61
    Post Thanks / Like
    Have you got the means to run the linear actuator yet on the voltage you intend to use it on? You could always attach progressively heavier weights to it to see what it can comfortably lift. From there you can figure out how much and how fast you can theoretically lift with it in your bot with different arm lengths for your lifter. Then you can see what the actuator is capable of and decide if it is going to be suitable for you or decide if you want to find something else.
