Results 1 to 3 of 3
Thread: Sqwiffy wheels
    Roboteer
    Status
    Offline
    Name
    Infinite Monkeys Fighting Robots
    Location
    Stratford upon Avon
    Posts
    28
    Hi,
    has anybody experience of running a 2 wheeled robot where the wheels/motors are not side-by-side and the motors are overlapping?
    You may ask why and the reason is that we have some Ranglebot motor/gearboxes. Using them means that your bot is immediately over 30cm wide and we wanted something narrower.
    Thanks
    S.
    overkill's Avatar
    Member
    Status
    Offline
    Name
    Nick Martin
    Robots
    Mr Mangle - Australian 2015 Featherweight Champion 2016 UK Gladiator Shiny Scissorhands Decimator
    Location
    Sydney Australia
    Posts
    888
    A friend built a 2WD wedge bot with off-set wheels like you described. It worked surprisingly well and drove almost as well as a bot with in-line wheels. I think the secret was to keep the centre of gravity low and right over the wheels.
    Member
    Status
    Offline
    Name
    David
    Location
    Blackpool
    Posts
    1,698
    i've run a few robots that way and it's pretty good. If you put some weight at the front where the wedge is they sit pretty flat. Sometimes I find a round head allen bolt sticking out the bottom helps, you position them strategically and adjust the height.
