Results 11 to 20 of 22
Thread: Featherweight Wheels
  1. #11
    Anttazz's Avatar
    Member
    Status
    Offline
    Name
    Tony Smith
    Robots
    Rusty (HW) Cicatrix (FW) Scot-Bot/Tiny (FW) Rover (FW) Eggbeater (BW)
    Location
    Glasgow, Scotland
    Posts
    1,537
    Having spoken to a machinist at work, we are now able to produce 80mm wheels for Saturn motors!
    These wheels will fit the 12mm shaft and will have the 3mm key to attach them to it. Costs will be similar if not identical to the wheels with nut inserts. As with last time, if there is interest here I would appreciate knowing if it is worth us undertaking or not.
    We are also able to offer machining of any custom parts, be it wheels, hubs, mounts or any other armour components made to order. Our machinist is happy to make custom fit hubs to any wheels size you may need if a suitable wheel can be found and demand is there.
  2. #12
    Member
    Status
    Offline
    Name
    Jack Tweedy
    Robots
    Tempus Fugit (HW) Vanquish (HW) Neutron (HW) Bulwark (FW) Tempus (BW) Ash 2 (BW) Phobos (BW)
    Location
    The Isle of Sheppey
    Posts
    210
    Count me in for some Saturn wheels, 100mm dia would be preferable but I should be fine just adding some bike tyre to up the diameter of the 80mm ones.
  3. #13
    Do you have any wheels in stock for Saturn gearbox?
  4. #14
    Anttazz's Avatar
    Member
    Status
    Offline
    Name
    Tony Smith
    Robots
    Location
    Glasgow, Scotland
    Posts
    1,537
    Not yet, I'm still waiting to see if its worthwhile making them before I do. If there is it'll be August/September before I start production.
  5. #15
    Roboteer
    Status
    Offline
    Name
    Henry Nourse
    Robots
    Is It Cheese? (BW), Turntable (FW)
    Location
    Winchester
    Posts
    21
    We'd definitely be interested in a few of the drill motor compatible wheels, would make new projects much easier to start at a uni house without things like a drill press!
  6. #16
    Theo's Avatar
    Roboteer
    Status
    Offline
    Name
    Theo
    Robots
    Oberon - FW, Titania - AW, Voodoo - MW (under construction), Project 2 - MW (under construction)
    Location
    Manchester
    Posts
    202
    Are you planning on making a new batch of these for drills anytime soon?
  7. #17
    Anttazz's Avatar
    Member
    Status
    Offline
    Name
    Tony Smith
    Robots
    Location
    Glasgow, Scotland
    Posts
    1,537
    I'm currently looking into it, I have had quite a few requests.
  8. #18
    Roboteer
    Status
    Offline
    Name
    Tom Walkinshaw
    Robots
    Unnamed Featherweight
    Location
    Glasgow
    Posts
    3
    Do they interface with the GR-EP-45 from Gimson? Looking for a pair of wheels to mount
  9. #19
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Michael
    Robots
    AW: Osu, Ikari, Ramu / BW: Shu! / FW: The Honey Badger / MW: Kaizen (Building)
    Location
    Somewhere on the Wirral
    Posts
    686
    It is worth noting that Gimson do also sell a wheel hub that fits the GR-EP-45 perfectly, so you can select a wheel with a flat face and simply drill 4x holes into them and mount that onto the wheel hub like you would a car wheel. Works fine for my Featherweight, which also uses the same motors.
    These wheels won't work with that motor anyway by the looks of things, the shaft is 10mm diameter with a keyway, the wheel's internal diameter is 12mm diameter but then again, AntTazz did mention did say that they might be able to machine to fit so worth enquiring?
    Team Kaizen
    BW: Shu! (Build Thread)
    FW: The Honey Badger (Build Thread)
    MW: Kaizen (Build Thread)
  10. #20
    Maxamuslead's Avatar
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    "Blacksmith" (FW) Retired "Forge Master" (FW)
    Location
    Lincolnshire, Threekingham
    Posts
    383
    you could use THIS like Ocracoke suggested, or really anything that has the same keyway.
