Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Brushless motor for feather spinner?
  1. #11
    maddox10's Avatar
    Member
    Status
    Offline
    Posts
    2,381
    Post Thanks / Like
    Valkiri2 had a meassured top speed of 6000 rpm with a 405mm disk. Tip speed 450 km/h .
  2. #12
    maddox10's Avatar
    Member
    Status
    Offline
    Posts
    2,381
    Post Thanks / Like
    That motor is a tad low on power . 18.5V*60A= 1.1kw
  3. #13
    overkill's Avatar
    Member
    Status
    Offline
    Name
    Nick Martin
    Robots
    Mr Mangle - Australian 2015 Featherweight Champion 2016 UK Gladiator Shiny Scissorhands Decimator
    Location
    Sydney Australia
    Posts
    886
    Post Thanks / Like
    That SK3 motor should be fine for a smaller diameter weapon like a drum or a small disk, maybe not enough power for a larger diameter. As long as you gear the motor down, it will probably be fine to over-volt the motor on a 6S pack to get a more power out of it; power will be almost 1.6Kw on 22.2V. With a 2:1 belt reduction and running on 22.2V, the no-load speed at the weapon is a respectable 7,000 rpm.
  4. #14
    Danny B's Avatar
    Roboteer
    Status
    Offline
    Name
    Daniel Booth
    Robots
    Mecha Sombra (FW, retired) Ferrovore (FW, active) Tantibus (FW, in build)
    Location
    Leeds
    Posts
    162
    Post Thanks / Like
    Quote Originally Posted by maddox10 View Post
    Which one would you recommend for a 1.8kg bar, about 300mm across? And what gear ratio? I already know I'll be running a 5s lipo.
  5. #15
    overkill's Avatar
    Member
    Status
    Offline
    Name
    Nick Martin
    Robots
    Location
    Sydney Australia
    Posts
    886
    Post Thanks / Like
    It is almost impossible to find a higher powered out-runner designed for 5S; manufacturers have discovered that with new FET technology it is cheaper & easier to make low Kv, high voltage motors. Just a few years ago, it was rare to find medium to large motors for 12S batteries, now they are everywhere and motors above 1.5Kw designed for 6S and lower are becoming scarce.
    For a high powered motor on 5S, you will probably have to turn to in-runners like this: https://hobbyking.com/en_us/dt38-620...ner-motor.html. The smaller diameter means they have less torque than a similar power out-runner but that's the compromise you have to make to run at 5S.
  6. #16
    Danny B's Avatar
    Roboteer
    Status
    Offline
    Name
    Daniel Booth
    Robots
    Location
    Leeds
    Posts
    162
    Post Thanks / Like
    I suppose I could run a 6s at a push, would that be any better?
    Scratch that, I noticed your earlier comment and see a 6s can work ok.
  7. #17
    R9000's Avatar
    Roboteer
    Status
    Offline
    Name
    Rory Charlesworth
    Robots
    [AW] Anty-Clockwise 2 [AW] Brushless Pizza [FW] Aegis
    Location
    Sheffield
    Posts
    533
    Post Thanks / Like
    What batteries do most high-powered spinners use these days then? Are they mostly 12S to match the motors?
  8. #18
    overkill's Avatar
    Member
    Status
    Offline
    Name
    Nick Martin
    Robots
    Location
    Sydney Australia
    Posts
    886
    Post Thanks / Like
    More bots still use 6S packs that are easier to use with drive motors. I am headed towards 10 or 12S packs and I think other builders will too. The trick is to either run a small secondary pack for the drive motors or to dump brushed motors completely and find some small, high voltage brushless motors for drive.
  9. #19
    maddox10's Avatar
    Member
    Status
    Offline
    Posts
    2,381
    Post Thanks / Like
    Valkiri 2 used a 4S 8000mAh monster to power everything.
    Valkiri 3 went for a 6S 3300mAh pack for weaponpower and a 4S 2700mAh pack for the drive.
    Both used the NTM 5060, a motor suited up to 8 S .
    6S because the ease to find cheap packs and chargers and the fact we use the cheap SS190-200 ESC, what in theory should do 7S.
  10. #20
    overkill's Avatar
    Member
    Status
    Offline
    Name
    Nick Martin
    Robots
    Location
    Sydney Australia
    Posts
    886
    Post Thanks / Like
    True - its mush easier to make a 10 or 12S pack from two 5 or 6S packs. They are more common and much easier to recharge - I don't think there are many 12S chargers around just yet.
