Page 6 of 6 FirstFirst ... 456
Results 51 to 60 of 60
Thread: Rigid Robotics Build Diary - Flat Damon
  1. #51
    maddox10's Avatar
    Member
    Status
    Offline
    Posts
    2,377
    Post Thanks / Like
    I can't comment on the burn yourself and surroundings. I had that stage a few years ago.
    Practice and good tools are the things you need. Tools is just money, experience is easier gained with good tools.
    On wheels. I make an adaptor that accepts a hex 17 RC wheel on the standard 12mm diameter, 3/8 unf/M5left shaft.
    RC wheels are lighter and more grippy (if not ment for driftcars) than any other commercial wheel I used in the past.
  2. #52
    lowndsy's Avatar
    Astronaut
    Status
    Offline
    Name
    Steve Lownds
    Robots
    Flat Damon (FW)
    Location
    Derbyshire
    Posts
    141
    Post Thanks / Like
    Quote Originally Posted by cjsowry View Post
    You didn't use.the iron itself to pick your noise did you?!?!?!
    Came close! I'm the sort of chap who looks at the time with a cup of coffee in his hand - it's a wonder I'm still alive!
    The wheels I have on the way are some sort of hard plastic - I think Polypropelene. I had 100mm ones, but I need to step up to at least 125mm to clear the armour top and bottom so I have some blue rubber ones in the post. I tthink they are 10mm shaft, will have to check.
  3. #53
    lowndsy's Avatar
    Astronaut
    Status
    Offline
    Name
    Steve Lownds
    Robots
    Flat Damon (FW)
    Location
    Derbyshire
    Posts
    141
    Post Thanks / Like
    Right, back on the wagon after being super busy at work. I stripped down FD tonight to replace the drill motors with new Gimsons.
    The crimped wires are just temporary until I shorten them, but otherwise everything is running again and ready to be screwed back together. Lots of screws.
    The aim now is to be properly bullet proof before I move house in 13 days time.
  4. #54
    Roboteer
    Status
    Offline
    Name
    David
    Location
    Blackpool
    Posts
    1,682
    Post Thanks / Like
    Is your chassis 3d printed.
  5. #55
    lowndsy's Avatar
    Astronaut
    Status
    Offline
    Name
    Steve Lownds
    Robots
    Flat Damon (FW)
    Location
    Derbyshire
    Posts
    141
    Post Thanks / Like
    Nope, it's a pair of caravan ramps. Good for 8 tons of pressure, and even after I hacked it up and bolted the armour on I drove my Renault Megane over it with no problems.
    Impact damage and point pressure from axes, spinners and the like will be different - needs protecting with HDPE all over, but it was built to just be a big solid lump.
  6. #56
    R9000's Avatar
    Roboteer
    Status
    Offline
    Name
    Rory Charlesworth
    Robots
    [AW] Anty-Clockwise 2 [AW] Brushless Pizza [FW] Aegis
    Location
    Sheffield
    Posts
    533
    Post Thanks / Like
    It does look really solid, it'll be interesting to see it after a couple of battles.
  7. #57
    Member
    Status
    Offline
    Name
    Tim G.
    Posts
    59
    Post Thanks / Like
    In that case, I take back my unsaid idea that your chassis looked weak and silly.
    If you have used such a practicle and obvioulsy strong basis for your bot rather than mess around with unnecessary tech you should be difficult to deal with.
    Are the wheels a bit far back and do they have enough of the weight of the thing on them? Can you put any sort of balast/armour on the back of it to keep them down a bit?
  8. #58
    lowndsy's Avatar
    Astronaut
    Status
    Offline
    Name
    Steve Lownds
    Robots
    Flat Damon (FW)
    Location
    Derbyshire
    Posts
    141
    Post Thanks / Like
    Thanks, I think! It is just plain heavy all over, but there is a pretty sizable armour plate to bolt onto the back so weight on the axle shouldn't be a problem.
    I am considering trimming a section out of the front where Chaos 2 style flipper arms might usually catch it so that will save some weight at the nose end too.
  9. #59
    Roboteer
    Status
    Offline
    Name
    David
    Location
    Blackpool
    Posts
    1,682
    Post Thanks / Like
    God that's a good idea
  10. #60
    Andy's Avatar
    Member
    Status
    Offline
    Name
    Andy Russell
    Robots
    Pendulum, Telekinesis, Push 'n' Shove, Ion
    Location
    Birmingham
    Posts
    257
    Post Thanks / Like
    Neat idea, will be interesting to see how they perform
