Page 29 of 46 FirstFirst ... 19272829303139 ... LastLast
Results 281 to 290 of 459
Thread: Team Coolspeedbot: first feather weight robot
  1. #281
    K-cut source their own hardox for water cutting
  2. #282
    Ocracoke's Avatar
    Team Kaizen
    Ah right, so you can specify a CAD design with a specification of what sort of material and thickness you are after and they water cut it? Fair enough, worth bearing in mind.
    BW: Shu!, The Honey Badger
  3. #283
    Yeah just send them a dxf or dwg drawing and they can cut it in pretty much anything. They have a lot of material on stock so best to ask them what thicknesses they have before designing something. For hardox I think it's 4,6,8,10,35,40mm
  4. #284
    And now for something completely different.
    Spent the past day and today working on one pair of motor mounts made out of HPDE scrapes. Hoping to get the other side done tomorrow and monday so I can have a working test platform to fully test the drive of Wolf-E.
  5. #285
    Motors are now mounted and the wiring connected. Hopefully will get a test drive tomorrow.
  6. #286
    So I went to do the test run and... the receiver is busted. I had to check both motors, both ESCs until I found the fault that was stopping both motors from running at the same time. It appears one of the channels used for drive on the receiver is not working. At least it's a cheap part to replace.
  7. #287
    Pondering on drive configuration. Wither to go with gearboxes directly running the middle wheel and connect the front and rear wheels through pulleys.
    Or run the brushless motors to the rear wheels with another pulley and then run pulleys to the middle and front wheels.
  8. #288
    Personally I'd go with the first one, because a) it's harder to get high reduction out of pulleys (the gearbox will likely be much higher and won't slip) and b) I like Sewer Snake, and that's how they do it. :P
  9. #289
    I had figured that would be a factor but I'll need to mod the gearboxes to have extended drive shafts to support the whole wheel and pulleys.
  10. #290
    You can get extra long shafts for the Banebots P60 gearbox; making your own shafts is a precision job that needs both a lathe and a mill.
