Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Memoirs of a veteran roboteer
    Everyone seems to have an opinion on how to build a winning robot for Robot Wars I found,
    most turned out to be dreamers with concepts built around a radio controlled car and numerous ideas
    for weapons- most of which would be illegal even under the oldest rules like machine guns and
    electrical dissruption ect.
    I recall on one visit to a large salvage yard to purchase some second hand low pressure pneumatic
    rams for immortalis(C2001) with my then teamate, we got chatting to the main man of the salvage
    yard and after telling him what we wanted the parts for he voiced his opinion.
    He explained how he would build his out of hydraulic motors going on to say how quote: they go like
    bloody hell and they are strong as......
    This intrigued me, I dont think I have ever seen a competitor robot than runs on hydraulic motors
    I guess there wouldent be much room for a weapon once the pump and fluid tank was fitted.
    I know there are some modern magnetic mounted hyraulic drills that do spin very fast and are
    powerfull-perhaps a 4 wheel drive version or is it EEC says no
    There is at least one machine that tried an hydraulic drive motor.
    Seen that at the Newark Kit Car show in 2004. Used a single back wheel like Project One and armor like Mayor damage ,sawblades as a kind of Roman armor. I did believe it was a successor to Sumpthing. But I don't know for sure.
    The original plans for Tough As Nails were based around hydraulic drives and weaponpower.
    And of course, the chassis of Flextreme 2 has 2 hydraulic motors to power a set of tracks.
    By all means give it a go. I imagine the system will be heavier than a conventional drive system but at the same time I imagine the torque would be far greater.
    My pedestrian flail mower has a hydraulic self drive function and it will shift the 300kg with me behind without trouble up any incline.
    Technophobic ran Hydraulic drive with a small 2 stroke petrol engine I believe, this was back in series 2 and 3.
    Might be stating the obvious but you can only put down so much power when your robot is limited to 110kg. You would have to look at magnets or maybe EDF's to pull it to the floor to make use of all the torque and power.
    But it would be great though to see an all hydraulic machine again!
    It's interesting that hydraulic drive motors have been tried -but I'm probably with Alex on this-unless the
    robot is virtually glued to the floor all that torque and speed could be wasted-though high torque and speed with electric motors works well for storm.
    I probably wont build one myself as it would involve a complicated build and deep pockets.
    So slightly deviating from the subject but not the main title subject, I recall my first encounter with Smidsy.
    After taking part in series two and three of Robot Wars I took a back seat and didn't enter series four -I returned for series five with what my team and I thought was a robot with half a chance-Immortalis.
    Auditions were now via live events and we were asked to appear at Sheffield Arena.
    I wasn't the first to appear and Smidsy was filling in for a long list of robots that had broken down or not made the grade.
    So a brief discription of my robot....a single front wheel drive and steering system which is concealed so you
    can't see which direction the wheel is aiming .
    A 3 sided blade lifter running off 2 low pressure pnuematics and 2 hedge trimmer saws at rear and a light up garden
    planter at the back.
    Now its my turn to enter the arena-well that concealled wheel steering is fine in large car parks or the large arenas
    but small bull pens -its a no no and I managed to smash its light up planter into the side wall before it got into the arena and it dissintergrated.
    As in most battles it seemed to be over in minutes-we attacked the smallest robot in the arena and lifted it then put it down again I believe Smidsy atacked the third robot and quickly dispatched it.
    So Smidsy and Immortalis eye each other up the full lenghth of the arena ....then full pelt the hurtle toward the
    middle and clash and with a scene reminicent of a cat chasing a mouse in circles Immortalis took fright and was
    chased onto an engine block finally dispatched by shunt-anyroad at least we got on show 5
    Along similar lines as the hydraulic drive motors; the number of people that say 'you should put an EMP on it' or 'you should fire acid at the other robot'.
    How about a) you go and read the rules and b) rather than telling me I should fit a banned weapon on my robot, how about you go and build your own robot and stick whatever stupid stuff you want on it then watch as you're not allowed to compete with it.
    And pneumatic spikes, they're another "brilliant" weapon that would do a lot of damage
    I'm pretty sure there was a hydraulic motored robot in either series 6 or 7, I can remember there being big problems with it and the bench (and team) being covered in hydraulic fluid. It was a yellow robot, probably shaped like a computer but I can`t remember the name, Megahurtz?
    Ahhh the Pneumatic spike is always cropping up! They don't work!
    Nonono, you guys are doing it allll wrong. Just equip it with a nondescript 'death laser', like that BBC Radio 3 Counties guy said in an interview with Anthony Pritchard of the Behemoth team.
Tags for this Thread
