@Brandon - Yep, scoop on the front will be on its way soon!
@Overkill - Egg beater it is then!
More cad work today!
Figuring out the drive system. Pretty happy with it so far.
The blue parts are spacers to help add support to the framework without the need for more threaded rod/bolts.
All of the wheels will be 3D printed to include the pulleys in one single piece. I will be insetting bearings into these by pausing the print half way, inserting the bearings and then resuming the print.
The idler pulleys will be 3D printed also. Because I have complete control over their diameter with 3D printing, I will be able to adjust them to give the perfect amount of belt tension (hopefully!).
The motors are counter sunk into the alu frame and will be held in place with a 1mm or 2mm front plate.
I've changed the material of the outer wall to use HDPE and I have also cut out the majority of the material from the inner piece, making them 86 grams instead of 200!
THINGS TO DO:
Firm up the weapon bulkheads - I'll probably add a set of bolts either side of the shaft and another plastic spacer between the two walls either side.
Add scoop - Design and integrate some form of scoop. Probably a similar idea to the mini flip out ones I printed out as a test. This will help to push opponents up into the spinning weapon.
Add weapon motor mountings and belts - Need to think about how this will work. Thinking of using two o-ring style belts for it.
Housings/shock absorbers for electronics - Thinking of putting these inside a little box which is shock mounted onto the frame. Hopefully this will take some of the stress away from the electronics.
Design an egg beater style weapon - Replacing the drum design with an egg beater.
For all of the 3D printing I will be using two types of filament.
The first one is Taulman 910 Alloy. This stuff is STRONG. I'll be posting some strength tests of the stuff when the new spool arrives next week. They have some stats on the website for it here: http://www.taulman3d.com/910-features.html I'm hoping it will be a nice light yet strong alternative.
The second filament I will be using is called Ninjaflex. Its a rubbery filament that can stretch and bend. With a durometer of 85A it seems perfect for tires and shock mounting things. I'll be playing around with different uses for this stuff a lot. One idea is to make little pouches to put the ETC's/receiver inside of.
