Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 67
Thread: Torrent's build diary - a dream coming true!
  1. #51
    Argos drill motors have a static winding resistance of around 1 ohm, giving them a stall current of ~12A at 12V; I've been running mine on £6 chinese 20A ESCs for a few events now without much trouble (ok, so I had one FET die, but that's more to do with the fact it had no cooling and was wrapped in heat shrink). It's going from forward to reverse suddenly that causes the high current peaks, but those are very short lived unlike a stall... If they had an 85A stall at 12V they'd be giving out more than 1 KW, which means it could give a Bosch 750 a run for it's money :P
    Basically, you're never gonna toast a TZ85 in a fight even if you ran your Lipo straight through it; they say 85A, but the FETS in there are collectively rated to 260A continuous, and they've been shown to handle peak currents around that; You'd blow your battery long before you blew the ESC (Which is potentially worse, but not the point :L)
    The fights at the Heavy events are 3 mins long with up to 30 feathers in the arena at once (though it's usually less than half that)
  2. #52
    Ahh fair enough, I used the Gimsons GR02 stat sheet to figure that out, though I realise they may be slightly different motors...
    Will certainly back up the point though that you're highly unlikely to cook a TZ85 - I was running a stalled speed 900 on one of mine for a good 20 seconds, and that's still in the machine now so you've no worry in that sense. Mount them right and they'll be fine for a long time, just don't velcro them to your baseplate like I did then take a direct hit from a spinner haha
  3. #53
    On the subject of spinners; I've so far found it's much more important to design a robot that can survive a fall from 15 feet onto solid ground than can take a spinner hit; there's only the championships and one or two other events which allow active spinners to fight; the majority are all just featherweight melees where the Heavyweight floor flipper is your main enemy :L I've been hurled into the arena ceiling a fair few times by that thing (and also thrown around by Explosion and Flow to name a few) and driven off fine, whereas I'd likely be toast in seconds if I came up against a spinner (my armour is only 5mm HDPE). You should be fine with your 10mm HDPE though, just need to make sure it's all held together fairly well.
    By the sounds of it once you've got your wheels you should be well set to build a fairly solid little feather
  4. #54
  5. #55
    All sounds good to me!
    How are you mounting your motors out of interest? I found that to be the hardest part with those drill motors...
  6. #56
  7. #57
    Hotglue kinda works on HDPE. Not the most solid connection, but it sticks and can fill gaps.
  8. #58
    The voluntary donation for AWS 45 is £1 per robot entered to help cover the costs of the venue... So wouldn't apply for a bystander... I'll be the one trying to orchestrate the 6 robot cluster bot, and will have a sign about N2xV speed controllers in my pit area :L Hope to see you there!
  9. #59
  10. #60
    Thanks, look forward to it! Would be great to drive a feather around just to get an idea of how it feels, especially in a big open space with nothing to hit! Drove around one of the little public-driven things at RoboChallenge last year and wedged myself in the arena wall thrice... Don't worry, I'll be more careful with this!
    Tried to do a bit of soldering. First time with XT60s so I wasn't too sure how to go about it. How do you melt solder inside a connector? So I tried soldering just at the top of the terminal. Went alright but it was a bit loose and I didn't belive that's how you're meant to do it Looked it up online and this guy in a video I found pre-heated the terminal a bit, melted some solder into it and, whilst it was 'still hot' quickly bunged the wire in. Piece of cake.
    Well, the solder solidified pretty much instantly. Guess I didn't pre-heat the terminal enough or something. Anyway, I was left with solder blocking up the terminal. My attempts to remove the blockage ended with me heating the terminal enough to melt the plastic around it, causing the terminal itself to slide about half way out of the connector housing. I decided it couldn't be salvaged so I cut the wire I had semi-soldered in.
    This is with my ESCs. I know, I lack experience (this isn't my first time soldering, I just haven't done it too many times) and I didn't really know what I was doing so I probably should have started with something less expensive. Anyway, the wires come with pre-soldered tips. Nice and neat. I thought I could do that. This guy in the video had just melted some solder over the wire and it had soaked it up. Easy. I ended up with a sort of wiry club that didn't fit into the connector terminal. So, one hour later, I'm minus a female XT60. I'll try to clean up this mess tomorrow and practice my soldering on random little bits of wire and the ruined XT60 so I can figure out what I'm meant to do.
    Sometimes I feel like I'm too inexperienced, but then so is everybody before they get some experience in. I guess the difference between you lot - professional engineers, seasoned robotics enthusiasts, specialist-subject university students - is that I'm only beginning to have these experiences.
Tags for this Thread
