Page 2 of 24 FirstFirst 123412 ... LastLast
Results 11 to 20 of 233
Thread: Rango - Build diary
  1. #11
    Where did you get those gears and motors from? Seems extremely compact, that kind of setup for drive!
  2. #12
    Quote Originally Posted by Eventorizon View Post
    Lol, but you aren't building that one are you! I admit Rango looks nothing in comparison but it'll probably cost a 3rd to build lol.
    Quote Originally Posted by Flag Captured View Post
    The motors are now discontinued/out of stock it would seem. They were originally from here: http://www.pollin.de/shop/dt/Mjk0OTg...HC885G_AS.html
    The right angle gears are for cheap 4" angle grinders. Got a set of 3 on ebay from China for 12 quid delivered :P. They're pretty rough in truth, both in finish and meshing, but I popped open the kind of grinder they go in a while ago and they were worn in and smooth running. The belts and pulleys are all from www.beltingonline.com.
  3. #13
  4. #14
    Bulkheads are now being machined, I'm soon going to order a Spektrum dx6i and a 5s Optipower LiPo. Once that's done I'm going to go across to the workshop and start making anything I can to make assembly once the bulkheads arrive that little bit faster. Ball is gradually getting rolling, sadly it's now less than two months until the champs!
  5. #15
    Mounting plate, standoffs and shaft support. The bearing will sit into the bulkhead this lot bolts to.
  6. #16
  7. #17
    Quote Originally Posted by shakesc View Post
    Its getting harder to source decent sized brushed motors. Noticed that these are still up for sale http://www.ebay.co.uk/itm/2009126068...84.m1423.l2649
    Grab 'em while you can!
    http://www.ebay.de/itm/Graupner-Spee...item417cbe3621
  8. #18
  9. #19
    I wouldn't buy that, £36 for the motor, £11 for postage and £12 import charge.
  10. #20
    The progress in your build skill Ellis just gets better and better!
    How did you make the brushless plate?
