Page 22 of 46 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 459
Thread: Team Coolspeedbot: first feather weight robot
  1. #211
    Quote Originally Posted by Albear View Post
    because that's what he does all his engineering on Although, he's built more successful robots than me to be fair
    Oh I see
  2. #212
    6 Renders of Wolf-E showing off the new panel parts to hold the side panels.
  3. #213
  4. #214
    Quote Originally Posted by Giles View Post
    Are you going to Insomnia? Best get building soon if so!
    Sadly not this time round, Wolf-E is most likely not going to be finished this year unless I can save enough money to get the hardox water cut.
  5. #215
    Small update finally worked out the mounting for the removable link and how the mount fits and is attached to the bot.
  6. #216
    That looks like my first plan for my removable link. I would have a big hole and was even going to finish the edges so they were nice and neat and looked awesome.
    After reading other peoples experiences with removable links they do seem to be a weak point of any bot so tucking it where it couldn't be bashed seemed advisable. Spinners in particular would put it at risk.
    Having a pull cable (none live) meant it could be put a bit more out of harms way but kept accessible.
  7. #217
    Panels laid out, it could be ready to export as a DXF and time to get a quote from K-cut.
  8. #218
    Quote Originally Posted by lowndsy View Post
    I don't really have anywhere else to put it.
  9. #219
    So as the issue has been raised, is there any suggestions on where to place the removable link and how to better protect it? Cause where I placed it in the CAD I though was ok cause it gives easy access for removal.
  10. #220
    Ocracoke's Avatar
    Team Kaizen
    I think it works where it is but I would add potentially add a raised profile around the edge, so it has a tunnel around it leading to the link (doesn't have to be very tall, just thick I would think to be of benefit). That would help protect it I think.
    BW: Shu!, The Honey Badger
