Another great Montage Jarvis :) Preferred the music of the last one but that's just me. Given I now have the computing power I will be having a go at a montage myself :)
Just discovered this recording on the phone, 120fps of gladiator goodness.
https://youtu.be/Q4kRny7y_H0
After all this time... turns out Endeavour was skied by Galactus, not by DB10! 0:55 to 1:00!
no, DB10 definitely hit us, the massive gauge on scoop where he hit us proves that!:
http://i1288.photobucket.com/albums/...pskhymyuk2.jpg
Galactus also hit us though, which probably then flicked us up on to DB's disk, as see by the drum grazes on the other end of the scoop:
http://i1288.photobucket.com/albums/...ps9wlsj9lf.jpg
So in reality, we were hit by two spinners at once- hence explaining the the HUGE hit!
Yeah, I heard about the massive mark in your scoop after I wrote that :P
Galactus's side goes up first, then there are the sparks as DB10 engages, a unlucky combination of hits, or lucky depending on your position ;)
meh, it was alright really. All it did was pull out the LED wire- which I finally got around to fixing last week ;)
Yer, we just bolted on the other scoop and then went straight back in to do a whiteboard with nipper and night fury. It took it quite well really!
