FW 4WD Good Starter Bot
Looking into selling Cicatrix, my 4WD pushbot as I don't do too many events anymore and 1 HW 1 FW will probably do me for the moment.
It's a 4WD drill powered rambot on 100mm Robochallenge wheels powered by NiCADs at 19.2v. If it is someone new I can include a charger too, you would just need to make up a lead/leads.
It currently has TZ85 ESCs in there which I can sell with or without. Chassis is 20mm Nylon, 16mm RG1000, 6/8mm HDPE and 3mm mild steel. Most recently ran in Dublin and had some ground clearance issues but it's usually ok on a metal floor, maybe the scoop could do with a but of a grind to make it run a little better. I will include a couple of drill motors/gearboxes too to keep as spares. You'll need to fit your own radio equipment but that is easy enough.
Open to offers, let me know if i've missed anything. Photos to be added.
1 Attachment(s)
