Brilliant thank you! Any ideas on what I should look for nut wise?
Thanks a lot!
Will :)
i use these, however it isn't threaded all the way through
https://www.ebay.co.uk/p/?iid=191818...&crdt=0&chn=ps
Is this the kind of thing you mean? **Link**
Was thinking if i can find a small enough bore then i could just screw it on?
Thanks for the reply!
Will :)
It would be a 3/8 Unc, and the brass nut thing would be called a brass coupling nut. Normally they are sink plated steel in their common form.
I made some easily on the lathe if you have access?
If you are able to, you could become a member of a local Hackspace or Makerspace where you will find like minded people and tools to help out.
Which wheels did you go for? I could make some and sell them to you for you to insert?
Renting equipment wouldn't be suitable for a lathe, and even the smaller ones from machinemart etc wouldn't be up for the job, although could do it at a push.
I made mine from plywood. Photo shows one just mocked up, have since covered with tyres just screwed on. Attachment 6697
Tony those wheels look cool are you going to add some bike rubber ?
Yeah I have.
Attachment 6698
Attachment 6699
