Looking at their youtube page, i can see it being a very budget printer and results may be ok, not amazing, https://www.youtube.com/watch?v=NRo0mRXw_Gk
Mechanically it just feels a bit too cheap IMO
Flashforge printers have a good rep.
Thanks - and for £100 more you can get The basic Flashforge I see. So message is save your money.
Back to the original question, depends what you want to 3D print with it.
My budget go to recommendation for FDM printing these days is the CR-10. A solid machine that once set up is a hit the button and leave it machine. The stock hot end will struggle with nylons and anything really high temperature but for most purposes, the base machine will do the job grand.
I guess also, what are you wanting to print on it for your heavyweight? brackets for electronics or wanting to print gears?
I'm looking to make brackets, moulds, case for electronics etc. Doesn't need to be too strong... can I do this with the above suggestions? Thanks for your help so far.
Cr-10
if this is all you want it for, then yes you can, remember, that some printers are not enclosed, so you may want to stick to PLA, or build a chamber for your printer to go in.
So to print using ABS I need an enclosed printer? I hope to build feather weights too so may want to print pulleys if possible.
I'll do some more research online.
I'm afraid to say you aren't going to be using a 3D printer to make usable pulleys for a featherweight. Beetle is pushing it. Ant weights love 3D printed bits. Unless you are using something fancy from mark forged (v expensive machines with similarly expensive materials), the parts simply wouldn't be strong enough.
The odd bracket or custom casing for electronics is where they are handy. Beyond that, not really.
