7 Attachment(s)
Beetle and feather parts for sale
£Offers for any of the below items plus whatever carriage fees to get them to you - or pick up at any of the events I'm going to.
Botbitz 10A brushed ESC x2 - used
These controllers are from Knight of Ni, so are used. Were working when the robot was scrapped. Have XT60 connectors fitted. Sold as a pair only.
Attachment 8670
Turnigy Plush 30A - used
Used once but otherwise as is. Stock firmware. Has XT60 and bullets connected, though you will want to receive shrink wrap them as only electrical taped.
Attachment 8671
Turnigy Plush 30A - as new
As new however the shrink wrap has been removed, so you will need to add some new stuff. Never powered on so no idea if it works.
Attachment 8672
9V UBEC - as new
I haven't used this at all, have no use for it, no idea if it even works.
Attachment 8673
20KG servo - used
Used for the lifting arm in Knight of Ni. As that bot has been scrapped, no need for it now. Is missing the mount off one side from where it has been mounted. Worked when removed.
Attachment 8674
Sabertooth 5A 2 channel speed controller - used but as new
Used once on an experimental antweight but doesn't really make sense.
Attachment 8676
Set of 4 80mm X 40mm castor wheels - new
Were intended for a Featherweight design I'm no longer going to do. Ideal for bike tyre tread to be applied. Note these have needle bearings so designed for a 12mm dead shaft setup.
Attachment 8675
