1 Attachment(s)
A200S ESC - Based upon the VESC®*-Project
The A200S is a 200A 16S ESC, based upon the VESC®*-Project.
* VESC is a registered TM, owned by Benjamin Vedder
The A200S is now open for pre-orders!
Attachment 7754
Timescale:
Preorders are going to be ordered on the 5th March if all goes well. Meaning they will be shipped out in the middle of April.
Specs:
- 18 FET design
- Weight ~800g
- Dimensions 110x105x30mm
- Waterjet 3mm copper bus bars
- Waterjet 10mm thick aluminium heatsinks (Stackable)
- 8AWG cables for input and output, with choice of 8mm bullets or lugs.
- STM32f405 Cortex M4 microcontroller
- 6x 100v 1000uF High-Ripple United Chemi-Con Capacitors (2 internal, 4 on external board)
- TVS protected 5v rail, suppied from receiver
- 15-75v rating, 16s LiPo maximum (Rating at 80v (90v maximum) on the current shunt amps, so need a bit of margin to account for ringing/transients
- 200A (13.4kW@16s) continuous for a few minutes
- 300A (20kW@16s) burst for a few seconds
- All standard VESC® features (CAN, SPI, Encoder/Hall support)
- Same amazing VESC® performance with sensorless motors.
- Designed specifically for combat use. Absolutely no heavy components on the boards which might fall off with shock.
- Each unit is hand built and will be rigorously tested before sale using a range of motors. (100W, 2200w, 5300w, 9800W) If I have the motor you will be using then I can set it up for you before sending it.
Testing status:
Testing will be finished in the next few days. With just the sustained high current and high voltage tests to run.
Current tests:
100A continuous - Works fine.
130A continuous - Works fine.
150A continuous - Works fine.
200A continuous - Waiting on motor generator pair setup
300A burst - Waiting on motor generator pair setup
ERPM Tests:
120000ERPM - Works fine.
VESC features:
BLDC - Works fine.
FOC - Works fine.
DC - Etek testing to follow.
I/O:
PPM input - Works fine.
CANBus - Works fine.
ADC input -Works fine.
Motor Tracking:
Sensorless tracking - Works fine.
Hall Sensors - Works fine.
Encoder - Testing to follow.
Motors tested:
Turnigy Rotomax 1.2 (1.9kW) - Works fine.
Turnigy Rotomax 50cc (5.3kW) - Works fine.
Turnigy Rotomax 150cc (9.8kW) - Works fine.
Revolt RV160SH 58KV (8/15kW) - Works fine.
Etek-R - Testing Soon.
Price:
Preorder price is £400 /unit for everything (Heatsink, connectors, cables, extra capacitor board) + shipping.
If you need any changes to the heatsink, like threaded mounting holes, then I can do them for free.
Warranty:
I will repair any that are damaged at the price of the parts and shipping. Plus a small free depending how long they take (less than £20 max). (If it is obvious that it was smashed by a weapon then it might be a bit more :P)
Will post some pics and videos over the next few days.
How to order
If you would like to pre-order then please send me a pm. Or Email teamtriforceuk@gmail.com
